Ansys Learning Forum Forums Discuss Simulation 3D Design The way to create parameter for the angle. Reply To: The way to create parameter for the angle.
jgshin
Hello Atharv,
Thank you for your answer.
I did same as you did(select single angular direction and then rotate) but the Parameter button didn’t appear as shown in the picture below.
(I did it on my collague’s computer, but there was no difference.)
Is there any option to turn on to use parameter?
Best Regards,
Jugyeong Shin
