Ansys Learning Forum Forums Discuss Simulation General Mechanical Truss Joint on Symmetry Vertex? Reply To: Truss Joint on Symmetry Vertex?
peteroznewman
What are the results if you don't use symmetry and instead have two truss elements?  Why do you even want to use symmetry?
If you have truely used truss elements and not beam elements, there are no rotational degrees of freedom, only translational degrees of freedom exist in truss elements.
