Pressure outlet
    • vipul.gupta
      I am simulating fluid flow. At the inlet of domain, i am giving mass flow rate inlet boundary conditions. At outlet, I am giving pressure outlet boundary condition with a static/gauge pressure using UDF (because the outlet face has inclination) I have a query regarding the sign of pressure formulation term. Should it be negative or positive?
    • Federico
      Pressure in Fluent is given as gauge pressure, so it will be relative to the Operating Pressure set in Fluent. The sign will depend on this Operating Pressure.
    • vipul.gupta
      Thanks for your response.
      I am using operating pressure value equal to 101325 pa. My query is on sign,
      whether I should use -dens*g*y or dens*g*y ?
      I am asking because y=x[1] provide the y coordinate with sign (outlet is on the negative y) . So, should I add minus sign in the F_PROFILE formulation to make pressure positive?
  • The topic ‘Pressure outlet’ is closed to new replies.
