Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Geometry import causes “OnRefreshTransferData failed!!”-error › Reply To: Geometry import causes “OnRefreshTransferData failed!!”-error
March 27, 2024 at 4:08 pm
Albert
Drag and drop the Maxwell system to the right of the geometry block, not on top of it. Then click on the geometry block and drag it to the Maxwel geometry to make the link. You can't drop the Maxwell straight on top of the Geometry block.
