Ansys Learning Forum Forums Discuss Simulation Electronics Coupled voltage at an antenna port with 50ohm load resistance Reply To: Coupled voltage at an antenna port with 50ohm load resistance
Praneeth
Hi Lalit Kumar,
Thank you for reaching out to the Ansys learning forum. Your patience is much appreciated.
You need to use both HFSS and Circuit inside the Ansys Electronics Dektop for this analysis. Please use HFSS for designing the antenna set and then link this HFSS desigh with Circuit, add required components and then do a linear network analysis. Kindly go through this video from our Ansys Innovation Course library to see the steps involved in this analysis - Cosimulation Using Ansys HFSS and Circuit - Lesson 2 - ANSYS Innovation Courses. Please note that this video may cotain some steps which are not required for your case.
Best regards,
Praneeth.
