LS Dyna
LS Dyna
    • yjg298
      I want to proceed with the analysis of the ball hitting the glass and breaking it. The photo below shows the plate made of aluminum using 18.MAT_POWER_LAW_PLASTICITY. I want to change the aluminum material to glass material. I want to use 280.MAT_GLASS. Can you give me an example? What I am using is the free version, LS-PrePost.
    • Ram Gopisetti
      Hi Yoon,
      Please refer to comments given by my colleague in the followign link
      /forum/forums/topic/windshield-glass-roof-material-modeling/
      Cheers, Ram
      • yjg298
        Thank you for your answer! However, the example in the link you provided cannot be run on my computer. If you don't mind, I'll show you an example I made so you can tell me what's wrong. Looking forward to hearing from you!
        • Tonmoy
          Hi Yoon,
          The example file is in *.tgz extension, or in gunzip format. Please use winrar or similar software to extract the input deck residing inside it. If you're using terminal use can use the command tar -xvzf /path/to/yaris_windshield_mat_280_pse.tgz to extract those.
          Thanks,
          Tonmoy.
    • Dale Chittenden
      Can you post the example you made here so we can see?
      tunnel rush
    • yjg298
      Hi Dale,
      This is an example I created. The model disappears after 2.18seconds. Please tell me what's wrong.
      https://drive.google.com/file/d/1OMTiGYcBIPhgGc_9w50GFTNuNWNTy8yW/view?usp=drive_link
  • The topic ‘MAT_GLASS’ is closed to new replies.
