Ansys Learning Forum Forums Discuss Simulation General Mechanical Element volume in USERMAT Reply To: Element volume in USERMAT
David Weed
Hi Eric,
If you add all of the contributions from the integration points, then you should get the total volume of the element. e.g., this is the print out of a 2x2x2 hex element with 8 integration points (which we would expect the volume to be 8 units^3):
element num           1
 int point num           1
 vect2 value  0.999999999999100
 element num           1
 int point num           2
 element num           1
 int point num           3
 element num           1
 int point num           4
 element num           1
 int point num           5
 element num           1
 int point num           6
 element num           1
 int point num           7
 element num           1
 int point num           8
