Ansys Learning Forum Forums Discuss Simulation Fluids Named selections not being converted to labels – Ansys Fluent Reply To: Named selections not being converted to labels – Ansys Fluent
Gregory Harrington
Federico that sounds like the best option for me. I figured I would have to do all that set up prior to meshing.
If I create the imprinted surface after there is a solution then isn't the mesh not conformal on the imprint? or does the solver do some type of interopolation. I am thinking the imprinted surface will "cut through" some cells instead of the cells on either side of it be conformal.
