Command for Menetrey Willam input parameters
    • Rommel Jr. Landicho
      Hi! I am trying to model a reinforced concrete beam using Menetrey Willam Concrete. I am trying to insert the mechanical apdl command snippet under the concrete in geometry tree but this error keeps showing "An unknown error occurred during solution.  Check the Solver Output on the Solution Information object for possible causes." and does not show any output.
      Here is the command:
      /PREP7
      ! ELASTIC CONSTANTS
      MP,EX,1,3.0E9                             ! 3 GPa and 0.2 poisson
      MP,NUXY,1,0.2
      TB,CONCR,1,,,MW
      TBDATA,1,40E6,6E6,46.4E6     !40 MPa compressive, 6 MPa tensile, 46.4 MPa biaxial
      TB,CONCR,1,,,DILA
      TBDATA,1,9                               !9 dilatancy angle
      TB,CONCR,1,,,HSD6
      TBDATA,1,0.001104,0.0035,0.3,0.3,0.01,0.05 !Linear softening parameters
      ! Helps with convergence
      TB,CONCR,matid,,,MSOL
      TBDATA,1,2,1,1e-3,100,10,1e-20
      ! Command for open and closed cracks, crushing and cracking of concrete
      TBDE,CONCR,1,,,
      TB,CONCR,1,1,9,
      TBTEMP,0
      TBDATA,,0.3,0.8,6,-1,,
      TBDATA,,,,,,,
      The reason why I am inserting the command snippet for input parameters of Menetrey Willam instead of just typing in the Engineering Data is that I want to include an APDL command for closed and open crack of concrete, cracking and crushing as shown below.
      TBDE,CONC,1,,,
      TB,CONC,1,1,9,
      TBTEMP,0
      TBDATA,,,,,,,
      I realized that when I input this alone, it overrides all the input parameters I typed in the Engineering Data so I concluded that the input parameters should also be in the command snippet.
      What should I do with the command snippet so that it will work?
    • Ashish Khemka
  • The topic ‘Command for Menetrey Willam input parameters’ is closed to new replies.
