Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Wrong domain extents read in Fluent from time to time › Reply To: Wrong domain extents read in Fluent from time to time
Hello Federico,
I use double precision all the time and I also change the unit to the same one everytime I read the mesh. This problems haven't been solved yet.
Besides, I found that there are also some precision problems when using iso-surface as shown below.
As you can see it, the minimum z-coordinate is not computed as same in "iso-surface" and "scale". It's so weird. I'm thinking that there shouldn't exist so large error which is only in e-3 level. It need to be know that I use double precision and generated the mesh in FluentMeshing.
The error is so large, I think, and if I post-processing using the value on this surface, obviously it would cause increase error. I wonder if the precision problem will still exist if I export the solution data into other post-processing software like cfd-post, paraview, ensight though I seldom use them.????
