Best Multiphase Model for Liquid-Vapor Phase Change (Fluent)
    • mert.berkman
      I have a gas which may change phase (turn to liquid and vice-versa) in the computational domain. I will be using a Real Gas Property (RGP) table for the material. Which options should I select under Multiphase tab to properly set this model?
      Thanks
      Mert
      Which do you think you should be using? Consider volume fraction and phase dispersion. If you're messing with RGP tables it's not a simple model so initially I may ask more questions than I answer.
    • mert.berkman
      Hi Rob,
      I'm thinking of using (homogenous) mixture 2-phase model. Does that sound right to you?
      Thanks
      Possibly, as I don't know what you're doing it's difficult to say.
  • The topic ‘Best Multiphase Model for Liquid-Vapor Phase Change (Fluent)’ is closed to new replies.
