Ansys Learning Forum Forums Installation and Licensing Ansys Products Ansys Thermal Desktop – SINDA Failed Reply To: Ansys Thermal Desktop – SINDA Failed
Jaime Ormeno
Ok, thank you so I checked the Intel OneAPI 2024 and did come across an error there. I followed your steps and fixed it and now I get the same things as what you shared in your image, no errors. However now I got an error when I tried to run the example in the steps again. I tried to open up the TdDwgLauncher and run the case but the example model isn't there anymore in the AutoCAD software and when I try to run a case I get an error. I'm not sure what to do.
