Ansys Learning Forum Forums Discuss Simulation Fluids About modelling the tube side flow as a solid cylinder Reply To: About modelling the tube side flow as a solid cylinder
Ashen Perera
I have attached velocity field around the baffle , what are the steps I should take to solve this problem in prssure drop. also what do you mean by node values on and off ?
