Ansys Learning Forum Forums Discuss Simulation Fluids About modelling the tube side flow as a solid cylinder Reply To: About modelling the tube side flow as a solid cylinder
Use Fluent, and zoom in around the baffles. You may need to look at the velocity field too. Possibly compare node values on & off.Â
