Ansys Learning Forum Forums Installation and Licensing Ansys Products Ls-dyna dynamic relaxation. Reply To: Ls-dyna dynamic relaxation.
Jim Day
That means the distortional kinetic energy is continuing to increase, perhaps because the applied load is still increasing?   You should ramp up the load with a fairly short ramp time and them hold the load constant.   You should see convergence reduce at some point after the full load is applied.
