Ansys Learning Forum › Forums › Discuss Simulation › Preprocessing › Matrix27 in harmonic analysis workbench › Reply To: Matrix27 in harmonic analysis workbench
March 18, 2024 at 3:46 pm
Chandra Sekaran
I did not check your R definitions but one thing I noticed is you are changing the TYPE to 200 with emodif command. But you also need change the real ID to 200, don't you? Like 'emodif,all,real,200' for the matrix27 properties to take effect.
