Ansys Learning Forum › Forums › Discuss Simulation › Fluids › How to know the mass flow rate at outlet surface when using DPM model? › Reply To: How to know the mass flow rate at outlet surface when using DPM model?
March 18, 2024 at 7:25 am
luna6362
That's a useful information to me.Thank you so much.
So if it is uncoupled in my case.
Is it okay to use this simple formula "total flow rate/num tracked*escaped track" to calculate the mass flow rate of outlet in the end?
I got this calculate method idea from this instruction.
https://ansys13.ansys.com/KnowledgeArticles/Phase-1/2058026/2058026.pdf
