Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › An internal solution magnitude limit was exceeded › Reply To: An internal solution magnitude limit was exceeded
March 17, 2024 at 11:32 am
After applying ‘Displacement’ support with constraint in x,y and z direction in all two nodes of the ‘Diaphragm’ member, my Model is running. But this is wrong method to give ‘Displacement’ support at that nodes. Is there any other option to get rid from above errors.
Also after giving ‘Displacement’ support, in modal analysis first 8 modes frequency is zero and rest 4 modes nearly zero.
Please help me.
