LS Dyna
LS Dyna
Running more simulations at a time and extract results without manually opening
    • gangolu
      I need to automate running simulations and extracting results without manually opening each simulation. I'm using LS-DYNA to model blast loading on steel columns. Can someone provide a solution for this, preferably using MATLAB?
    • Armin
      Hi Jaswanth,
      If you're using LS-PrePost for post-processing your model, it is possible to use macro commands to automate the process. Please look up online for "LS-Prepost Command Line Interface" and you should be able to find some resources online.
      https://lsdyna.ansys.com/command/
  • The topic ‘Running more simulations at a time and extract results without manually opening’ is closed to new replies.
