Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › How to Constrain Planet Gear Train › Reply To: How to Constrain Planet Gear Train
March 17, 2024 at 12:42 am
The connections between the parts seems correct. The configuration you describe has a fixed ring gear. You applied a torque to the revolute joint between the planet gear and the carrier. How is that achieved in reality since the planet gear circles around the sun gear? I can see either 1) applying a torque to the sun gear relative to ground and controlling rotation of the carrier axle relative to ground or 2) applying a torque to the carrier axle and controlling the rotation of the sun gear.
Under Analysis Settings, did you turn on Large Deflection?
