3D Design
3D Design
Initial Surface mesh generation failed
    • Chen Wang
      Initial Surface mesh generation failed. Automatic fallback is not supported for surface meshes. Please switch to alternative meshes manually.
      My model is sure to face to face.
    • Mrinmoy Bharadwaj
      Hello Chen,
      Usually surface mesh failure results from geometry issues with the CAD . However, it would be difficult to find out the cause just by looking at a pitcure of the model here. However, I would suggest to check and clean up your CAD for any geometry issues and retry the simulation.
    • erik.kostson
      Hello
      I would suggest also to post this in the electronics forum as this forum is about CAD (SC/Discovery, DM etc), and not about HFSS or Q3D.
      /forum/forums/forum/discuss-simulation/electronics-2/
      Thank you
      Erik
  • The topic ‘Initial Surface mesh generation failed’ is closed to new replies.
