Ansys Learning Forum Forums Installation and Licensing Ansys Products Rocky licensing / Academic multiphysics Reply To: Rocky licensing / Academic multiphysics
jlcyr
More technical details:
All computer are windows based.
Licence server is running Ansys 2024R1 licence server it’s a windows server in an ESX VM.  Port 1055,1056,2325 are open
First machine which have A100 GPU had previous version of Ansys/Rocky (2022R2, 2023R1 and R2) but is now with 2024R1.  It’s a windows server used in TS mode (remote desktop).
Others machines with GTX GPU and without GPU are clean 2024R1 install (windows 10 and windows 11).
Licensing show correctly (Rocky_Prepos, Rocky_HPC, …) we have 25/250 Research/Teaching Multiphysics licence downloaded from portal and installed.
Ansys Fluent (2-way coupling) is running fine with any number of CPU/Core.  Ansys Rocky is working fine everywhere with 0 to 4 CPU, complaining about HPC licence when trying to use more than 4 CPU.  Rocky see the GPUs (A100 and RTX) correctly, lunch with the A100 correctly but complain about no GPU licence on the machines with RTX.
So it’s 1-Limitation to 4CPU only for Rocky and 2-Unable to use GPU licence other that on the A100 that are problematics.
Ok for #1 I still have no clues.. Got some other computer to use GPU, they had previous version of ansys installed.. could it be some licence config issue?
And for #2 It's really a licence server communication issue, Software checkout Rocky_prepost and Rocky_solver correctly but return an error for Rocky_HPC
Excerpt from licence file (all three are present)
INCREMENT rocky_hpc ansyslmd 2024.1214 permanent 450 FF9981C33171 ...
INCREMENT rocky_preppost ansyslmd 2024.1214 permanent 25 FE84D82497EC ...
INCREMENT rocky_solver ansyslmd 2024.1214 permanent 25 EE827C9CC28E ...
From FlexNet debug log (user/host have been hidden):
10:22:34 (ansyslmd) IN: "rocky_preppost" ---@---.ca  [9816]
11:35:34 (ansyslmd) OUT: "rocky_preppost" ---@---.ca  [1264]
11:36:45 (ansyslmd) OUT: "rocky_solver" ---@---.ca  [14544]
11:37:37 (ansyslmd) IN: "rocky_solver" ---@---.ca  [14544]
11:37:48 (ansyslmd) OUT: "rocky_solver" ---@---.ca  [3092]
11:37:48 (ansyslmd) UNSUPPORTED: "rocky_hpc" (PORT_AT_HOST_PLUS   ) ---@---.ca  [3092] (No such feature exists. (-5,346))
11:37:48 (ansyslmd) IN: "rocky_solver" ---@---.ca  [3092]
