Ansys Learning Forum Forums Discuss Simulation Optics User Material&Surface properties of Metal in SPEOS Reply To: User Material&Surface properties of Metal in SPEOS
Anthony Leger
If you are looking at the reflected light from this material the simulation results will be accurate. But, if you want to represent a metallic material in transmission you will need to use Ansys Lumerical to model the material. If you need help with this process please contact your local Ansys support team.
