Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Variation of outputs from MotorCAD to Maxwell › Reply To: Variation of outputs from MotorCAD to Maxwell
March 13, 2024 at 5:44 pm
MirandaH
The current should be close between Maxwell and MotorCAD, could you compare an example from MotorCAD with exported Maxwell? Are the results close with example file on your end?
