Ansys Learning Forum › Forums › Discuss Simulation › Process Integration and Design Optimization › Automation of Aqwa Load Simulations in Mechanical Using Scripts › Reply To: Automation of Aqwa Load Simulations in Mechanical Using Scripts
March 13, 2024 at 3:58 pm
James Taylor
Hi Mike,
Thanks for getting back to me. I have included this command - it works for the first attempt but will not work in a for-loop for subsequent steps. It updates the timestep but not the load values.
I've tried to use this command with the cable force modules also. It doesn't appear to work when these modules have question marks beside them, which happens each time the hydro pressure time step is updated.
I've attached an image of my code, I hope it makes sense.
