Ansys Learning Forum Forums Installation and Licensing Ansys Products Residual stress and LTB check Reply To: Residual stress and LTB check
ashish.khemka
When you apply an initial condition then can you try to see if the response is linear for a linear model. For example a bar stretched in elastic region initially will try to regain its shape. Does you see a similar behavior if you simplify the model. This may be a simple check for the model setup.
Ashish Khemka
