March 13, 2024 at 3:53 am
March 18, 2024 at 3:27 pm
George Karnos
Ansys EmployeeIf you are running the free academic Student version, you can only specify a maximun of 4 cores.
Looks like you set it to use 6 cores.
Change to 4 and it should run. -
April 25, 2024 at 9:49 am
Latanya Parks
SubscriberÂ
I think we should reduce the number of cores (processors) used for the simulation. For example, set the core usage to 4 instead of 8.
To do this:Â Go to the Analysis Options or Solver Settings.
Adjust the core count to a lower value (e.g., 4 cores).
Save the settings and re-run the simulation24. geometry dash liteÂ
- The topic ‘Ansys Mechanical (Ansys License Manager Error: Not enough HPC Parallel Licenses)’ is closed to new replies.
1598
1386
1242
.png)
