Ansys Learning Forum Forums Discuss Simulation Fluids Mass Issues with Mixture Multiphase and Species Transport Reply To: Mass Issues with Mixture Multiphase and Species Transport
Nicholas Strack
Ahmed,
Firstly, thank you for the response!
My internal volume is 1.953E-5 m^3 and just looking at the so2-liquid component, which makes up 0.594 of the overall mixture mass and a density of ~1200, this gives me 13.9g. If I check the acetonitrile-liquid component, 0.228 and ~786 for mass fraction and density, I get 3.5g. I am taking mf*Density*volume. These values are also in rough agreement with some real values from a manufacturer.
I am a little perplexed by this problem. Side note, for the materials, the liquids are defined with constant density and the vapors are defined as real-gas-peng-robinson as I am working with temps and pressures near the critical point.
I would think Fluent is using the Peng-Robinson EOS to determine the density for the vapors and taking the constant density values listed above for the liquids and performing a similar calculation, but I cannot understand how it is coming up with a value so far off.
Any additional ideas you can give me would be appreciated!
