Ansys Learning Forum Forums Discuss Simulation Optics Incorporating Non-Square Susceptibility Matrix (χ²) into Simulations Reply To: Incorporating Non-Square Susceptibility Matrix (χ²) into Simulations
Guilin Sun
Unfortunately right now we do not handle such non-square cases.
Since the non-square susceptibility means interaction between different field components, I do not think you can integrate it to get the square one, except that you have theoretical guide.
If you want to use script to do the integration here is the script:
integrate - Script command
