May 29, 2019 at 4:55 pm
rubz
Consider a vertical pipe with an inclined pipe intersecting it. cold water flows through the hot pipe at a certain temperature and velocity and hot water flows through the inclined pipe at a certain velocity and temperature. heat transfer between the fluids and flow patterns will be investigated.
It is required to provide pictures of the velocity and temperature patterns along the vertical tube and normal to the inclined tube at 3 different positions. how does one obtain cross sections of the flows after performing simulations on the geometry in ANSYS fluent?Â
May 29, 2019 at 5:10 pm
- The topic ‘Heat transfer and flow patterns of fluids in intersecting pipes’ is closed to new replies.
1638
1386
1242
