Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › MAPDL convection load with variable film coefficient and bulk temperature › Reply To: MAPDL convection load with variable film coefficient and bulk temperature
Hello Francesco, can you go to Post1 (example commands below) and see if the loads are being applied properly?
/post1
set,last ! last time point
cmsel,s,nozzle_selection ! select the nodes of the nozzle
nlist ! list and make sure the X coordinates are in the range of 0.13 to 0.20
sflist ! based on time and X you should be see if the right values are being applied from the table.
Right now I am not sure whether you are saying the load is not being applied correctly or if you are saying the load is being applied correctly but the results are wrong.
