Ansys Learning Forum Forums Discuss Simulation General Mechanical “AnsysWB Module has stopped working” when viewing results in Mechanical Reply To: “AnsysWB Module has stopped working” when viewing results in Mechanical
Gary Stofan
Occasionally the user settings become corrupt.
Try the following:
Exit Ansys completely.
In the File Explorer address field
Enter: %APPDATA%
…An Explorer Window will open
Open the Ansys folder…
If you are using verison 2021R1, then the folder will be v211
Rename the v211 folder to v211.old for the appropriate version.
