Ansys Learning Forum Forums Discuss Simulation LS Dyna Deflections not matching for simple cantilever beam check Reply To: Deflections not matching for simple cantilever beam check
Jim Day
To confirm, did you try *ELEMENT_SHELL_COMPOSITE with 6 layers of 0.5 mm each instead of 3 layers of 1.0 mm each, and the 6 layer run gave a more accurate deflection?   What was that deflection?
