March 11, 2024 at 3:28 pm
jackzhe551
SubscriberIn the heat exchanger design,1. How to set the dynamic physical properties of phase-change hydrogen? Can refprop be invoked, and how? Can you give a tutorial of a phase change heat transfer case? (hydrogen varies in temperature from 15K to 50K, while 15-33K is a liquid and above 33K is a gas) 2. Once the refprop is set, is the rest of the operation consistent with the non-phase conversion thermal operation process? What should I pay attention to?
March 11, 2024 at 4:45 pm
Forum ModeratorDuplicate /forum/forums/topic/phase-change-hydrogen-in-heat-exchanger/
- The topic ‘phase change hydrogen in heat exchanger ,how to set in fluent?’ is closed to new replies.
