Ansys Learning Forum Forums Discuss Simulation General Mechanical MAPDL convection load with variable film coefficient and bulk temperature Reply To: MAPDL convection load with variable film coefficient and bulk temperature
Chandra Sekaran
One suggestion is to go into the postprocessor Post1, do SET command to bring in a result set at a particular time point. Then display / list the convection loads. This will show the actual values used at that time point. This will be good way to check if you got what you intended.
