Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Compression test › Reply To: Compression test
March 8, 2024 at 5:55 pm
Hi peter, thanks for your reply. It is possible for u to guide me on how can i introduce geometric imperfection into the geometry, as I am new to Ansys.
And also is it because the material properties defined are all from tensile test data and not compression. Because the outer layer is a type of nylon fabric.
