Ansys Learning Forum Forums Discuss Simulation 3D Design Measure total length Tube Reply To: Measure total length Tube
Keyur Kanade
You can also use Move command to align geometry to global XYZ coordinate. Then select Measure and then select all using box selection. It will give x, y , z extends.
