Ansys Learning Forum Forums Discuss Simulation Preprocessing 0: mpi_accept: warning Reply To: 0: mpi_accept: warning
Can you try meshing in serial (ie one core) if you've picked several in the launcher. However, the stairstepping may be a clue that there's a problem else where in the model: are you just meshing a box?
