Ansys Learning Forum Forums Discuss Simulation Photonics Facing Problem with Reflection Reply To: Facing Problem with Reflection
Amrita Pati
Hi Kawshik,
At this point it is hard to say if this is expected or if there is an issue. In some devices, it can take a long time for the energy in the simulation domain to decay. What is the mesh accuracy that you are using? As a starting point I will recommed you to reduce the mesh accuracy to 1 or 2. Then increase the simulation time by 10 times, to see if you are able to reach the auto shutoff level.
Let me know what happens.
Amrita
