Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Large deflection convergence problem › Reply To: Large deflection convergence problem
March 6, 2024 at 9:44 pm
Your vessel radius appears to be around 10e-5 meters. If R_in is the radial displacement in meters, you are approaching a solution in which the radius has almost doubled. The model is probably unstable at that point.
