Ansys Learning Forum Forums Discuss Simulation General Mechanical Please anyone save me from the problem which is ‘Contact is Inactive’ Reply To: Please anyone save me from the problem which is ‘Contact is Inactive’
peteroznewman
It is wrong to assume that an Inactive contact is a problem to be solved. It is not. Inactive contacts are normal and nothing should be done to "fix" them.  Yes, you can cause them to go away by changing Auto Asymmetric to Symmetric, but that is unhelpful and you have no reason for doing so other than your wrong idea that an Inactive contact is a problem to be fixed.
