March 4, 2024 at 11:36 pm
TAEHYEON GABRIEL KIM
SubscriberI got the intensity of an optical system by using Speos.
The results are only report and XMP file.
How can I get the actual values from the XMP file?
(e.g. datasheet about output spectrum by wavelength, optical characteristics by angle)
March 7, 2024 at 8:49 pm
nomad
SubscriberHi TAEHYEON,
You can use VIRTUAL PHOTOMETRIC LAB to measure values from xmp result.
Please visit https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v241/en/Optis_UG_LAB/Optis/UG_Lab/making_measures_analysis_166427.html to check how to use VIRTUAL PHOTOMETRIC LAB.Here is some example steps for measurements, and please contact local Speos support team if you need more help.Â
0. open the xmp file
1. Set measurement profile and adjust it. It's line acrossing the result map in this case
2. You can see value of section from 1.
3. You can export the data to txt file in 4
5. You can check spectrum data
6. Spectrum data can be saved as .spectrum
7. .spectrum file contains wavelength and intensity -
March 13, 2024 at 5:12 am
SubscriberThank you very much for your kind reply
- The topic ‘How to get a value from XMP file (SPEOS)’ is closed to new replies.
6745
1324
1047
