Ansys Learning Forum Forums Discuss Simulation Fluids What limit the speed of simulation in Fluent? Reply To: What limit the speed of simulation in Fluent?
Dato
Hi SRP,
I cannot change the grid resolution or turbulence models because I just want to test that if the speed of simulation will be improved after I had add one more 32G memory using same case. But I found that the simulation speed wasn't improved greatly as expected after I had dual channel memory.
