Ansys Learning Forum Forums Discuss Simulation Fluids 2D airfoil lift and drag results Reply To: 2D airfoil lift and drag results
Plot some contours of velocity on the case you're not sure about, run another 20-50 iterations and replot the contours. What is happening in the flow? Compare those with the case(s) that are converging well.
