March 4, 2024 at 1:55 am
March 5, 2024 at 2:23 pm
ashish.khemka
Forum ModeratorTranslated text:
The previous example can be run, but the prompt is always negative.
The volume. Particles are lost, the time displayed by ls-run is hundreds of days, even the negative volume appears, how to solve this problem
March 5, 2024 at 5:18 pm
Chris Quan
Ansys EmployeeDoes your model contain a soft material? Were the elements with negative volume coming from a soft material? If yes, it is true that for low modulus materials such as rubbers, you may encounter error message about "negative volume". You may also observe high hourglass energy as well in these elements. Thus check the hourglass energy in GLSTAT and MATSUM to see if the soft material has large hourglass energy comparing with its internal energy. If yes, you need to refine the mesh of the soft material.More explanations and instructions on negative volume can be found from LSDYNA Negative volume in soft materials (ansys.com)If your model doesn't contain a soft material, you can try the following method to prevent negative volume error:- Set ERODE = 1 in *Control_TimeStep to erode elements by small time step. The small time step limit can be specified in *Control_Termination.
- Reduce time step safety factor. The default is 0.9. You can try smaller time step safety factor such as 0.45, 0.33, etc.
- Use different hourglass controls such as IHQ = 6 to 9.
- Use different contact keyword such as *Contact_Interior.
More instructions and discussions about negative volume error can be found in LSDYNA Negative volumes in brick elements (ansys.com)
March 5, 2024 at 7:32 pm
Ram Gopisetti
Ansys EmployeeHi Jiazhi,
Try with the following pointers by giving importance to the first point as in the follows
The way to avoid the negative volume error in SPG is to try the following changes in the SPG section card.
- Turn off erode and mass scale in the control timestep ( most recommended).
- Increase the dilation DX, DY, and DZ parameters to say 1.8
- Set the SMSTEP = 5 and increase pdamp to -0.01. ( 8th parameter in the row 3 of section SPG card)
Cheers, Ram
May 24, 2024 at 9:36 am
May 24, 2024 at 9:38 am
- The topic ‘spg question’ is closed to new replies.
