Ansys Learning Forum Forums Discuss Simulation Fluids Fluent: Heat flow (solid-liquid) with natural convection Reply To: Fluent: Heat flow (solid-liquid) with natural convection
da.wanek
Hello Rob,
when recreating the residuals graphs, I wanted to go a little further down (I still had the termination criterion for the residuals set to "Default", i.e. 0.001).
The large error in the heat flows has decreased massively with smaller residuals. (If the residual of the continuity is 10^(-6), the deviation of the heat flow is only about 0.1%).
Thanks for the suggestion!
