3D Design
3D Design
SWEEP FUNCTION
    • angelo
      Hi, I want to construct a cylinder-like geometry in design modeler. First I sketched the profile of the cone then I sketched the circumference and used the sweep function on the profile to follow the circumference. I have obtained the cone but inside this remain the sketch of the profile and whene I go for the mesh ( the cone is all fluid) I have the line inside the the fluid and near tht line I have high quality mesh but far of that line the quality decrease.
      How can I remove that line?
      Thank you
      In DesignModeler, at the bottom of the outline, it shows a list of bodies. If you have a solid body that is the cone and a line body, select the line body and RMB to Suppress the line body.  It will not transfer into meshing.
    • angelo
      No, I don't have any line body, I have only the solid body.
    • angelo
       Dear Mr. Oznewman
      I have made another geometry and this time I have create a surface from the sketch of the cone (I'm sorry I didn't mention the absence of the surface from sketch action in the first post). Now I have the surface you mentioned and I was able to suppress that. Now in the meshing I don't have the problem of HQ mesh near the construction line and LQ mesh far from that.
      Now I'm dealing with the mesh and this will be quite a challange. Thank you for your help.
      Kind regards
  • The topic ‘SWEEP FUNCTION’ is closed to new replies.
