Rope made of beam elements can not bend
    • marco.pedata
      Hello Ansys community,
      I try to do a transient structural analysis of a rope.
      To reduce computation time i modelled the rope using beams.
      However, there is no convergence.
      Moreover the rope does not bend (would be expexted as a result of prescribed displacement) but contracts or strectches depending on the direction of the prescribed displacement.
      I would appreciate tips that can pinpoint me to my errors.
    • erik.kostson
      Hi
      You need first a pretension (so pull cable to put it in tension), and then in a second step add forces to look at the bending of it.
      There are many posts if you search about this.
      /forum/forums/topic/need-help-in-modeling-pre-tensioned-cable/
      All the best
      Erik
      • marco.pedata
        Hi Erik,
        thank you. I will try that.
        best regards,
        Marco
      • marco.pedata
        I set the model type of the rope to cable and inserted a APDL Command to apply pretension and set the number of load steps to 2.
        However, the model still does not converge.
        Perhaps it has something to do with how I Prescribed the displacement (tabular data is zero until time for second load step starts because I did not find a way to insert tabular data that begins at the second load step)
        Do you have further advise for how to resolve this issue?
        Thank you in advance,
        Marco
  • The topic ‘Rope made of beam elements can not bend’ is closed to new replies.
