February 22, 2024 at 11:58 am
BALAMUGESH M
Subscriberhi,
i am doing simulation of a tank where, i need to give non uniform pressure from 1m above the top surface of the tank till end, like from 1m above to till end of the tank the pressure should increase. how to do this simulation, what is the best method to do in ansys mech.?? -
February 22, 2024 at 4:34 pm
Ankush Choudhary
Ansys EmployeeHi Balamugesh,
Please check out the below video to achieve this.
https://www.youtube.com/watch?v=BONKvfp5dsg -
Aurojyoti Prusty
Ansys EmployeeHi,
The pressure may vary linearly and you can represent by a tabulated data and import it to ansys mechanical.
You may please follow the below link for some discussion
/forum/forums/topic/time-dependent-non-uniform-pressure-function/
Thanks
- The topic ‘non uniform pressure applying method’ is closed to new replies.
