How to see orientation of fibers (composite)
    • Adisa
      Does anyone know how to see the orientation of fibers IN Ansys Mechanical.
      In the Layerd section I rotated fibers in relation to x axis, but the x axis in global coordinate system is normal.
      Thanks in regard.
    • jj77
      I have not done much composite modelling in ansys, but the information below shows how to visualise the fiber directions (help manual/ graphic options toolbar):
      Think though this is only valid when ACP has been used. If layered sections are used than Ex (say fibre for a ply) is along the element local orientation of X, and so on.
    • manmorcan
      I got some problems with this.
      I clicked on that symbol, but it doesn't work.
    • Wenlong
      The orientation will show up after you create a ply and click on it.
      Wenlong
  • The topic ‘How to see orientation of fibers (composite)’ is closed to new replies.
